Headgasket, again
SLoW_SHO_316
Runcarsnotwords
Connecticut
Here's a couple higher res pics of the damage. It almost looks like the head can be used as the gouge is not completely in the coolant channel.
SASHO91
Zoom Zoom
San Antonio,TX
Nick, even though it is not in the coolant passage, its still a stress rasier.
It will fail again.
Seems like you have two options...
1: take the head to a welder( a GOOD welder) and have them patch the hole. Then take it to get planed, but even then your still risking it.
2:take your losses and ditch that head, and find another.
or there is always option 3- ditch the sho alltogether... :shrug:
SASHO91
Zoom Zoom
San Antonio,TX
step 1-36-51
step 2-61-69
I dont have the sequence though, sorry... :frown:
BTW, the maximum waprage on the heads is .008''
SLoW_SHO_316
Runcarsnotwords
Connecticut
So max tq on the head bolts is 69 ft/lbs? That could be a problem that I tq'd them down to 80 last time I did this.
AREA 91
PA SHO SHOP
Area 91
If you torqued the head bolts to 80ftlbs, you are risking damage to the threads in the block.
