head unit won't come on after head gasket replaced...
aberdeenSHO
aberdeen
I don't get this at all... I went to get my head gasket replaced the other day and after the guy did the work on it my head unit won't come on at all???? I check the fuse for the actual car it self and it's fine. the car's clock works too if that helps any? I don't know if he snagged a wire under the hood or blew a fuse behind the headunit or what. I don't want to pull out the headunit though unless you guys think there was a way to blow that fuse. So anything you guys think may have caused my stereo problem any help would be very appriciated... I have a very nice system in there and i miss it!!! thanks a lot... payce
BeatDaSHO
Hatboro, Pennsylvania
yo man. just pull out the front of the dash right where the head unit is. there is like 4 screws that come out that pulls off the plastic right by the head unit. Then you have access to all of the wires from the head unit. Just check them all. And check the fuse behind it.
Greg
David Carpenter
