Having problems removing halfshaft
Devin
3.Slow
Pacific Northwest
I'm trying to take my driver-side half shaft out. Everything I've read says to just pull it out by the inboard CV. When I tug on it I can move it back and forth in the tranny but it won't pull out. What am I missing?
shotime1994
AirHammerAndrew
New York
Stick a screwdriver or prybar between the trans and axle then pry alittle. It will pop out then.
kevinspann
Don't take my advice.
Richmond VA
A small prybar, and a quick pry will pop it loose. ****, I used a pickle fork to get mine out.
TopGunnYFZ
Livonia, MI
Its got a clip on the end so you need to follow the advice above. Prybar and a quick pop should get her. Are you replacing the shaft?
Devin
3.Slow
Pacific Northwest
Not replacing. The boot ripped and sprayed all of the outboard CV grease out. I'm sending it back to Raxles to have them inspect it and replace the boot. The less damage I do to it the better. :)
Devin
3.Slow
Pacific Northwest
Man, you were not kidding about the prying. I got it off after about five minutes of changing position with the ball joint remover and some serious pushing and pulling. Thanks for the help!
jonheese
Used-To-Know-It-All
Fogelsville, PA
I find a 18mm-19mm wrench works as a great prybar on those, without damaging anything. And I've usually got one of each sitting in front of me anyway while doing that job. I just stick the open end of the wrench between the inboard joint and the transmission body and push/pull on the end of the wrench and it's usually out within a few seconds.
Devin
3.Slow
Pacific Northwest
I'm back!
I'm trying to remove the passenger side now. Alldata says to use a halfshaft adapter and a slide hammer. As luck would have it I do not have that tool in kit. I can't really see a way to pop a prybar between the intermediate shaft bearing and the inboard CV. Ideas?
jonheese
Used-To-Know-It-All
Fogelsville, PA
I just remove the intermediate shaft bearing from the mount bracket and pop the whole shebang out of the transmission the same way I did the driver's side. No adapter or slide hammer needed.
Just give the intermediate shaft a few good sharp tugs, and it should pop right out.
kevinspann
Richmond VA
Whaaa, adapters and slide hammers?
Nope, do what Jon said. Take out the two 10mm headed bolts that hold the carrier bearing to the engine, then it should just pull right out of the transmission.
TopGunnYFZ
Livonia, MI
Okay, I'll give that a shot tomorrow.
You can also take the bearing bolts out and drive around! Thatll pop it right out for ya. Ask me how I know lol and no I didnt do this but as luck would have it I have experienced that happening.
Mike Gallion
Marseilles, IL.
Both at once??
Hope you aren't pulling both of the half-shafts out at once without supporting the innards of your tranny. I seem to have read a thread or two on here cautioning such a move. Also seem to recall something along the line of a broom handle inserted into the tranny to keep all the internals where they belong.
Hopefully someone will chime in with firsthand knowledge soon....
jonheese
Used-To-Know-It-All
Fogelsville, PA
I think I've heard that before too, but I've pulled both at once with no replacement support at least a couple times and suffered no ill effects. :shrug:
****, when's the last time you saw pic of an MTX trans sitting on a garage floor with a broomstick (or similar) hanging out of it?
The diff is supported at both ends by tightly-clearanced bearings in cups built into the case-- I don't think it's going anywhere.
jayro
Auburn, In
When doing a clutch job you also remove both. I dont think it would cause an issue.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Don't sweat it. Nothin' wrong with trying to warn someone before they screw up something important. You know around here, if you're wrong about something, someone will definitely chime in to let you know. ;)
Devin
3.Slow
Pacific Northwest
Yeah, I definitely had both sides out. For a good five years or so. Still shifts too!
This time however, one at a time. I found that the greater the amount of dis-assembly I do, there is a relational rise in the amount of time it takes to put it all back together again. When I started this I told myself: I'll just build and install these struts and springs and have nice happy suspension! Then I take my wheel off and put my hand in CV grease...
Anyway, I took the two 10mm bolts off with a little combination wrench and tugged on the intermediate shaft and it came out after about a minute: easy as pie. I'm glad much smarter people than me or on this forum!
