Having an Idle Issue
Moonflair
Hey all. Sometimes when I start my car it revs to about 1300 RPMS and then just falls on its face. Sometimes it revs a little high and hangs but its ok.
However, it doesnt matter how the startup goes, I still have this odd issue. When Im driving and im accelerating I have no issue. But, when I let off the gas I have a surge. Im posting two links to videos. One is just the surge while the other is a WOT run to 80.
http://www.youtube.com/watch?v=i0bNU5H7qPU
http://www.youtube.com/watch?v=WOCMhJvVByM
Thanks for your input!
bubba
ATX Connoisseur
Fort Wayne, Indiana
Clean your maf, I'm having the same problem you are. Give everything a good checking over also
Moonflair
Well whoever put this aftermarket air intake just left this sitting there. Is it that important?
Also, I ended up cleaning out my IAC and my MAF. MAF was okay looking but the IAC basically was pouring out black crap. So I also hit all the electrical connectors with some cleaner and I plugged everything back in. Did the Idle reset process. Didnt work so well. Found out the last owner messed the throttle stop screw. So I played with that and then followed the proceedure..... Shes working great! I took her out for a few normal runs, then some WOT. Idles fine and doest have that surge anymore! Thanks Guys!
Moonflair
Well I thought it was fixed. Now when the car is cold it starts, then goes to idle and sputters and shuts off. I have to hold the throttle for a solid minute and THEN it idles fine..
thatSHOguy101
