Ground cable off neg post hot
jsndsky
cincinnati
Have 1989 SHO noticed that Ground cable off Neg post off battery is super hot to touch is not hot when key is off not hot when key is turn to accessories but as soon as you start cranking car becomes hot. Starter or connections not touching block. Any ideas
So changing the cable will fix it? Why is it that the short ground cable that goes straight from the post to the fender is hot but the heavy cable to the starter is not? Is it the thickness of the cable?
Try cleaning and tightening the end connection. Other wise you may need a new cable or new ends.
95azSHO
phx,az
I agree and was stranded in the Arizona desert half a day because I waited to change them out.
