91PDXmocha
I think our turbos are close to the same size , 60ar 63t .
How much psi do you run normally ? You said in your drag thread u where trapping 104 and was turning the boost up to 10 psi to try and get more mph . So you pretty sure this size turbo is not going to make much more power ?
I know Scott used the same turbo as me when he first started his remote set up and made over 300 whp ,might even of been 340+ whp . Maybe he will chime in here , he knows the remote system well .
edit - Scott made 358whp at 10 psi with the same turbo as me set up in remote style.
