Vince7
Hello, I performed my 60k check R&R Intake& valve cover Gaskets,plug well seals and also replaced spark plugs and wires Motorcraft all the way also sprayed b12 carb cleaner into air intake at the TB also checked valve lash ok i miked the shimms they are good. 1991 SHO
3.0 yamaha 103k i wasn't sure if a 60k had been done but i had oil in the plug wells and low spark on cylinders 3 and 4 checked codes and replaced 6cyl coil pack, i'm not sure how long it was running on 4 cylinders and now runs smooth but low on power and low idle, i checked for codes and none just code 11 and after running at 3,000 rpm the converters started glowing and still has low power. it sounds like a clogged exhaust especially the cats. any thoughts or ideas will be helpfull... Vince7
