gauges:advice&opinions
DavidT
TN
v8sho.com suggests the Stewart Warner line for a factory look.
What is the best way to hook up a volts gauge? (I searched here and at v8sho.com) Where exactly is the best place to splice into the instrument panel wire for the bulb?
Also, where is the best place to splice into for the volt reading?
I am also considering a tranny temp gauge. Do you have to tap into the pan fro the sender? :omg: What is the easiest/best way to install a temp. sender for the tranny?
You can pick up the instrument panel lighting at the headlight switch. The brown wire is the parking lamp circuit.
The tranny temp if it is a 1/8" pipe thread for the sender can screw into the EPC port on the top of the tranny under the TB. More than likely though the sender is 1/4". I would tap out the EPC port and install it here.
Volt meter wire can be connected to any hot in run or accessory wire.
f150fan
Los Angeles, CA
I have always been a fan of Autometer's products and have had great success with them in all my cars. Check out the autometer lineup as they have many choices of styles before you buy the Warners.
stephen newberg
Ladysmith, BC, Canada
I too would strongly suggest Autometer rather than Stewart. For my trans temp, it was a 1/4", IIRC, and I did end up doing a tap into the front of the transmission pan. No big deal, if done carefully.
pax, smn
DavidT
TN
Is the EPC port viewable without having to remove anything?
DavidT
TN
how in the world do you get the headlight switch/**** OFF????? I saw the writeup at the "other" website...
After you turn the switch on, then pull out, do you just FORCE the **** off?
I found out the HARD way that the trim piece around the **** is GLUED to the dash :doh:
thatSHOguy101
