Fuse #10 shorting out!
javve
SHO Lovin' It
Eastern Washington
Pull the multi-function switch towards you and it turns on the highbeams with the lights on or off but doesn't leave them on. ...tell a semi when hes passed you and can merge in front of you,
From the perspective of a past truck driver, they do not like you to flash them because it messes with their night vision. Rather they prefer you turn your headlights off then on to signal them. Being at the recieving end of this, I can sure understand why.
Alldata seems to have some nice diagrams. I have Mitchell here.
I have a 93 SHO ATX with the vinyl/cloth combo for the seats and no moonroof. I'm planning on changing the passenger seat to powered...
I'll have to unplug that module and see if it fixes my problem. If so then I'll have to open it up and clean the contacts. My fuse is out for the high beam indicator as when it's in the indicator is always on even when high beams are not. That could be why my FTP doesn't work right now. The Multifunction Switch was changed out and you can tell because it's a hard click when I turn my signal on for left or right turn. High beams work but no indicator without my fuse in.
thatSHOguy101
