From The Fire Back Into The Frying Pan
shogun
minnesota
first of i want to thank all the cats on here that helped me out. u guys were right on the money even when the stealership tried to do the do with no vaseline, BIG UPS TO YOU ALL and hence my next dilemma so here it goes: so i change out the ABS module (midnight was late on the delivery by the way)and the speedo works fine so i am not having that problem any more thank GOD, i drove it yesterday and just as i took the bend the SES light comes on, i have the codes pulled and what it is saying is that there is a CYLINDER MISSFIRE IN CYLINDER NUMBER 3, now prior to this i was noticing during idle that there was some serious hesitation i mean it was not idling smoothly at all so i did anticipate the SES coming on soon. this is the real problem, if cylinder 3 is misfiring how do i test if it is the plug, the wires or the distributor i mean how do i go about fixing it
second problem: i initially had my technician replace the ABS module cause i did not feel like being bothered so he did it for me but it is like he got rid of a potentially annoying problem by creating a new one because the ABS light is now a permanent fixture on my dash board. QUESTION: i anticipated this happening as well and to tell you the truth i dont care about the ABS system never have so i pose this to you, is there a way i can get rid of the ABS light?? i dont need this system so i dont care about it and would appreciate some answers on this as well
ONCE AGAIN THANK YOU ALL FOR YOUR HELP
kit352
holland, ma
#3 is almost certainly a coil. sadly #3 is in the back. autozone has them for the cheapest online, i just got one for $71.
i believe the abs light can come on due to air in the system. i also think some of the tuners can get rid of it but im not 100%.
Silvapain
Limestone, IL
Misfire #3 is a bad coil as mentioned above. If you've got the cash, pony up the money and replace all four bank 1 coils.
Easiest solution to the ABS light problem...pull the bulb.
I'd bleed the brakes again first, though, and see if it is air in the lines like mentioned above.
shogun
minnesota
when you say ""sadly", does this mean this procedure is going to be tough as **** to get done??and does any one have pics of the coils itself, when you say coils are these the little wires that go directly onto the spark plug or some thing different getting confused here
Silvapain
Limestone, IL
The V8 has COP - looks like this:
http://tinyurl.com/5lzzew
You have to pull the surge tank off to get to the four rear cylinders. Not nearly as difficult as some would like you to believe.
Exitwound
_McLovin_
Wisconsin
It really only takes about 20-30 mins. to get the surge tank off but if it's you first time count on much longer. Not hard though.
Brydakidz
It's SHO Time
New Jersey
Your lucky as **** your car even told you that one of your coils was bad.
The first time I had a mis i took my car to a buddy of mine who had a computer and pluged it into my car.
When another coil went, my buddy no longer had the computer so I just said screw it and replaced the remaining 7.
97SHOgt
Cincinnati, OH
I pulled the bulb in mine just because I couldn't stand looking at it anymore. You can get it out in five minutes tops. I could care less about the ABS, you don't need it. Tried to fix it once and it didn't work. Just be careful in rain or snow.
Does the AntiLock Brake light flash a two digit code when you first start the car?
shogun
minnesota
yes it does flash 2 times when i start the car my next thought was how did you know then i remembered i was responding to the god of SHO's, the SHO CZAR i now treat yours answers like gold cause u have saved my ass thanks again
So it's flashing 22?
B1922 22 Safing sensor output circuit shorted to battery voltage
This is either a short in the steering column or the clock spring is bad in the steering wheel, quick guess.
shogun
minnesota
I will be sure to plan my next vacation around your car repairs
im sorry ray its just that the people handling the project wanted to start charging for storage it got sticky there for tad, no worries man you'r still my go to guy, by the way i might need some coils, got any?
JoesSHO
Reality
I think he meant the ABS warning light flashes twice when he starts the car. I take it you meant that he needs to be on a code reader? My car has the ABS on as well, and the bulb is pulled now until I get around to fixing it. I'm subscribed to this thread... :)
Silvapain
Limestone, IL
You need a special code reader for the ABS system; a regualar DTC reader won't be able to talk with the ABS system.
The AntiLock Brake light should either stay lit and extinguish itself after the self test or flash two digit numbers Lamp Fault Codes when first turning on the key to run. If there is a problem while driving the ABS light will come on and remain on continuously.
Anti-Lock Brake Control Module On Board Diagnostic Trouble Code (DTC) Index
DTC Description LFC
B1318 Low Battery Voltage 18
B1342 Anti-Lock Brake Control Module Internal Failure 42
B1596 Service Continuous Codes 96
C1095 Hydraulic Pump Motor Circuit Failure 95
C1145 RF Wheel Speed Sensor Circuit Failure 45
C1148 RF Wheel Speed Sensor Plausibility Fault 48
C1155 LF Wheel Speed Sensor Circuit Failure 55
C1158 LF Wheel Speed Sensor Plausibility Fault 58
C1165 RR Wheel Speed Sensor Circuit Failure 65
C1168 RR Wheel Speed Sensor Plausibility Fault 68
C1175 LR Wheel Speed Sensor Circuit Failure 75
C1178 LR Wheel Speed Sensor Plausibility Fault 78
C1194 LF Anti-Lock Brake System Outlet Valve Circuit Failure 94
C1198 LF Anti-Lock Brake System Inlet Valve Circuit Failure 98
C1210 RF Anti-Lock Brake System Outlet Valve Circuit Failure 10
C1214 RF Anti-Lock Brake System Inlet Valve Circuit Failure 14
C1222 Wheel Mismatch (Any Wheel) 22
C1242 LR Anti-Lock Brake System Outlet Valve Circuit Failure 42
C1246 RR Anti-Lock Brake System Outlet Valve Circuit Failure 46
C1250 LR Anti-Lock Brake System Inlet Valve Circuit Failure 50
C1254 RR Anti-Lock Brake System Inlet Valve Circuit Failure 54
C1266 Anti-Lock Brake System Valve Power Circuit Failure 56
— No Module Communication
shogun
minnesota
well the thing is i am not pulling any codes except the worn out number 3 cylinder. shouldnt this come up too?i mean whatever is wrong with the ABS LIGHT should show a reading too right?
What kind of code reader do you have? Why don't you get the #3 cyclinder code fixed?
Unless you have the Ford NGS or something similar you are only able to read the OBDII codes. The manufacturer specific codes number in the thousands and will include such mundane things as whether your door lock is working when commanded.
shogun
minnesota
i dont have a personal code reader myself, i go to an autozone or parts store and have them pulled for me, however i am still in the market for a coil
