Friendly reminder
GotGrip?
Conversation Ruiner
Minnesota
For those of us living the 100+ degree outside life right now, makes sure you check your tire pressure. (Not damage to a SHO)
20210614 134702 20210614 134655 HDR 20210614 134508 HDR
limited02
Olathe, KS
That zoom zoom went boom boom. What the heck was the tire pressure set at originally before the heat ballooned it up?
Jordan_R
Missouri
Yep! My escapes tires were set at 32psi when it was like 30 degrees out. Just aired them down from 40psi couple days ago after a drive. Big difference from temp
Ta2dResqr
Central Ohio
The other 3 were 100+
So in other words, way over inflated regardless of temperature? 10 degrees is equal to 1-2 psi according to most sources. A temperature swing from 0-100 would only add about 20 psi resulting in around 55 psi.
GotGrip?
Conversation Ruiner
Minnesota
He supposedly "pumped them up until the bulge went away" last winter. Car came into the dealer for tire wear issues (duh) then parked it out front and left. Service folks heard the boom, they put tires on it and sent it to me.
shootinirons
