morpho18
Found My Vacuum Leak! (**PICS inside**)
A while back I had posted that my air was only blowing out the defrost and floor vents. Somebody told me that was because I had a vacuum leak. Well I found the culprit.
AC canister
There is a grey tab underneath the metal line with the 90* bend. The air is coming from a hole in this grey tab.
another close up of the grey tab.
Now, I need your help to tell me if there needs to be a hose underneath the metal one, as the hole the air is coming out of is definitely round and just seems like a hose should be there. If not, what can I use to plug the hole?
Thanks in advance.
Adam
AC canister
Thanks in advance.
Adam
