Found Clear Corners!!!!!!!!
Bizzy
I already have some on my car but I ordered some on behalf of a friend. I had them in literally 2-3 days and I think they look just fine. They're not OEM, but I think they still look sharp.
SHO92
Upper Freehold, NJ
Mine came last Friday. I haven't put them in yet, but they seem ok compared to some stock ones that I have. The only thing I really noticed different was a drain hole(?) on the corner light.
BTW, no DOT or SAE stamp.
Storm-Chaser
Shit Louis
I don't know that I would go that far, if they're the same quality as the last batch of clear corners that were coming from Taiwan. One major problem with them, is the rubber housing gasket deteriorates in relatively short time, expecially if you get paste wax in it. While not clear corners, I can get new OEM SHO corner/sidemarker lamps for $30 a piece.
yeah i got 2 sets from them and a set for my dakota,im pretty satisfied ,you get what you pay for.
0V3RC10CK3D
Washington
Clear Corners Installed:
Bizzy
What he meant was, they were a little on the cheap side but they still looked good and fit well.
OEM Orange = not sexy
Clear corners = Major sexy
In my humble opinion of course. ;)
The gasket on mine seems to be ok, they've been on there for a couple of years now. I don't go pulling on it very often to see if it's falling apart though.
DirtSHO
Philadelphia
Well here is an in depth look at them thru pictures. I can see where people are coming from when they say they are "cheap" since they seem flimsy compared to the Ford ones you've had on your car since day one. You must remember tho that the ones you're replacing have been out in the elements for a long time. There are really only a few major differences as far as I can tell - and they may or may not affect the "quality." I took pictures of my driver (left) side install to compare them. The 94 amber lens is always on top and the clear on the bottom in the following pics.
Up close amber vs. clear lens:
Sho007
Sho001
Side by side amber/clear lens:
Sho011
Up close amber vs. clear housing:
Sho013
Sho012
Now here's where the major differences are.
Rubber seal/weatherstripping:
Sho005
Sho018
And the plastic welds to hold it to the housing:
Sho014
The mounting studs:
Sho015
I noticed that the rubber seal had a little more "leeway" as in being more supple/flexible than the stock ones. But this should be normal since the stock ones have been baking in the sun/elements for over a decade making them stiff and brittle. I'm sure they'd be a little more like the clears when they were new or if I used silicone conditioner on them. Then the mounting studs are of a different design. I didn't notice a difference in strength since almost all newer headlights carry the exact same looking stud nowadays. I didn't mind because sometimes even Ford comes out with redesigned replacement parts for older cars. And lastly are the plastic welds that are on the clears look a little more "sloppy" than the ambers which is where I'm sure many of the concerns of the seal tearing away from the housing occur.
Here's before/after pics of them on the car:
Sho006
Sho016
Overall I noticed no major difference in "overall" quality in the clears when compared to the stock ambers. As far as the eye can tell, the fluted lens is exactly the same, the housing exactly the same, the chrome reflector exactly the same, and the rubber exactly the same. Only difference is it now makes my ugly yellowed headlights stand out even more between them and the super clear fishtanks.
Sho017
Hope that helped.
DirtSHO
Philadelphia
Oh and just to let people know. Both of those lights in the corner light up amber. To avoid the fried egg look I used Philips CrystalVision Extreme 194s for the marker light and switched out the plain white 3157s(? if I remember correctly) for Sylvania SilverStar 3157s in the signal light. CrystalVision Extreme also has a chrome-coated amber bulb in 3157 but I liked the look of the SilverStars better, they're coated in an oily-robocop-bluish tint. I avoided yellow LED bulbs cause they don't output enough light from the standard bases.
I switched from white to amber for the signal light cause I actually got pulled over once when a cop saw my turn signal "corner spotlight" was white. He insisted that they had to be amber even though I was trying to tell him his Crown Vic had the same thing! I actually think it looks better too and it still lights up the turning curb nicely.
I'll try to get more pics comparing the light output at night when it gets dark here later on.
1993MTXSHO
Its a Taurus...
Jersey
GUYS READ HIS FEEDBACK.
Im having problems with this guy already.
EDIT: sucks hes the only place we can get clear corners...
MD Ever
MeanestDad Ever
South Lyon, MI
No issues here either. Ordered on the 14th, received on the 19th and installed on the 20th. Fit perfect and look great! Didn't think quality was that bad either. I'm happy!
What problems are you having?
blownatx95
Minnesho on an alternate user name
cheeseville
i ordered one of the last pairs last night before the new auction went up.
they are in Taiwan so I hope its not a scam =p
You mean like you scammed Toolman out of his exhaust? maybe you shouldnt be worrying about clear corners and send Toolman his exhaust back. :wave: Hi Miethos.
DDakRT
Mississauga, Ont, Canada
Or how you scammed so many people out of their money MinneSHO? YOU should stop worrying about other people's exhaust and send everyone their money back.
So ironic that you of all people are lecturing others about scamming forum members.
Big thumbs down.
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
ok, I just read their e-mail over a little more and their way of dealing with out of US customers is totally bogus
here is their e-mail to me:
Hi,
S/H to CANADA we charge is $45.00 and we only do "off ebay" deals with buyers that are not located in USA, thank you
I put what I think is stupid in quotations
