Hi, just curious if you’ve checked/looked at your led bulbs flashing for a while to see if they are consistently flashing correctly.
I changed 726-13-01 to all zeros but -14- was already all zeros. The hyperflash goes away but the bulbs do not flash normally, consistently. They will flash fine a couple times and then they’ll kind of flicker. Occasionally the right side will actually change from amber to white mid-flash if my parking lights are on.
I don’t expect you to check yours now but if you do, make sure the vehicle is running and in drive. In drive is when mine have the most issues.
