1. Does anyone know what the threads are for such plugs?
2. Would a pipe fitting with the matching metric threads work instead of the "actual" plugs?
3. I have a 96 upgrade on the front will the plugs help the rear "catch up" to the additional breaking?
4. Is it easy to switch back to the stock way if im not happy with the upgrade?
5. Will my rear brakes heat up do to excessive heat?
6. You guys said there isnt much of a handling problem as long as you have abs. What about driving on snow, anyone used these and had rear end control problems?
Thanks for your indulgence.
