Few Problems
flosho
Shooting Flames
wisconsin
ahh just recently after hooking my cb in my car up my power locks and my power seats don't work
i don't have a owners manual.. but i checked the fuses and none are blown..what is wrong..?? i ghettoed the cb so it was hooked up through a fuse and aground.. what should i do??
Also my CE light comes on(wrong forum i know) but it goes on and off..it will come on for a min and go off for 10-20 30 mins..
Machspeed
Former 1991+ owner
Santa Barbara, CA
Im not very good at this, but i see no one else is helping you. I would suggest taking all your cb components out and seeing if they still dont work. A multimeter may come in handy, but as i said before, i dont really know much about electronics.
flosho
Shooting Flames
wisconsin
I took the cb off before and still nothing... i checked all the fuses...
Is that all the fuses there is?? (underneath the driver colonm? in that pull down thing?)
projectSHO89
SHOless In St L
Check the 40 amp fuse in the engine compartment fusebox.
It suppplies the power to the door locks and the power seat.
Steve
89
As for the CHECK ENGINE light, you can install a short jumper wire between the SELF TEST INPUT and SIGNAL RETURN connections of the EEC TEST plug (on the firewall near the passenger side) and turn the ignition key ON. The CHECK ENGINE light will flash to show the codes. Here is a great link to explain the testing procedures and the code descriptions. Your '95 will display 3-digit codes and the link to their explanation is near the top of the page on the site below.
http://www.dalidesign.com/hbook/eectest.html
flosho
Shooting Flames
wisconsin
i don't have a owners manualso i don't know where all the fuse boxes are... umm.. oh i dont have keyless entry either..
