festiva engine swap finals..
NovaSS
Project MINIGUN
after much soul searching, loading the forum with stupid questions and input from you guys this is final design for the festiva / sho swap.
..... did I forget anything?
3.2 guts in a bored 1994 3.0 block, new rings, seals, bearings and gaskets.
heads had slight shave, a couple thousands max just to make them straight.
a/c delete
p/s delete
shosource UD pulley
190 walbro pump ( works fine with factory regulator even at idle)
3.2 injectors
36 / 31 MM over sized valves
bronze guides
"austrailian" valve springs
shonut +20 cams
mild port clean up ( nothing dramtic, cast flash clean up and matching)
BBB butterflies, BBB air horns in plenums
1 5/8 stainless long tube headers, dual cats / mufflers
aluminum flywheel
quaife
80mm lincoln maf
69mm TB
LPM ( with new shosource tune)
The car looks like it going to come in at 2300 lbs so the loss of torgue at low rpm hopefully will not be an issue.
100 1130
TopGunnYFZ
Livonia, MI
Do you not like PS? or does it limit performance? The ps pump died in my fiesta so im just wondering :D!
No need for it in something that small, and im going to guess the front end will be pretty light as there's nothing in there.
shogansta
Change Username
Istanbul Turkey.
real men dont need power steering or an auto tranny :)
Oh jeez... i have a manual in my car but my motor is up front and its a pain in the ass getting out of tight spots and i dont want to ruin the steering rack :(
[/QUOTE]No need for it in something that small, and im going to guess the front end will be pretty light as there's nothing in there. [/QUOTE]
yea i completely didnt think of that... That right there is going to be a sweet car when finished... :)!
krednjen
Kit car/90 SHO Derek SA TX
San Antonio TX
No power steering here.;) Of course beetle steering blows.
jthod
Mr. Goodwrench
Lincoln, Nebraska
Are you to make any kind of shield between you and the engine? (Noise and safety sake)
Inner fender covers between the wheels and engine bay?
NovaSS
Project MINIGUN
complete inner engine compartment out of aluminum and carbon fiber lined with a sound deading material, It will be carpeted over. fiberglass inner wheel tubs to keep out the dirt
firebat45
Edmonton
I've been watching this for quite a while over on FB. I just have a couple questions:
Are those ground control coilovers or something else?
What are "Australian" valve springs?
Looks great, btw!
NovaSS
Project MINIGUN
Looks great, btw!
The coil overs are "home made".
KYB struts with the coil perch cut off and sleeves/ adjusting rings installed to hold the Qa1 progressive rate coil over springs. I made up a set of rod ends ( bored and install helicoils )to match the thread of the shaft. I used a set of Mustang camber plate in the front with a set of sleeves I made on a lathe to match the diameter of the KYB shaft
I use KYB because they tend to be a little softer then others and with the reduced weight Im hopping they will work, The other reason was I needed a contstant diameter strut for the front end. I hone out the front spindles and slid the strut hosing down into it about 4 inches to reduce its heigth to match the room I had to work with on the festiva. Heck I can always change them.
"Australian valve springs" are aftermarket springs sold by FPS, they come from austrilia
any more pics???? stainless headers and exhaust.
100 1081
BlackonBlack89
burlington county,NJ
AWESOME!!!!!!!! as always.
Since ur talking about the end. Whats your paint scheme going to be??? And I hope to god someone good is doing the paint work.
NovaSS
Project MINIGUN
Paint will be silver with some minor black around the side glass, pretty much a stock looking festiva LX paint , this is also the original color of the festiva and I wont have to re do the engine ( gas tank ) compartment. Yes Im doing the paintinting. Heres my Nova I did a couple years ago. I did all the work on this one too.
100 0845 3
