High on Ethanol
Just Ain't Care
Many of you run e30 so this only mildly concerns you. I noticed over the course of almost a year, the difference between E50 and e85 isn't much as far as performance goes, unless you are really pushing the limits. Also noticed the sheetz e85 only drops to e75 in winter. As far as difference in data logs, the AFR is the main thing that changes with LTFTs, timing also changes by roughly 1degree.
The main reason for making this thread is to bring to attention the fact that no tuners adjust the lower rpm tables unless operating in WOT mode. This makes you realize that unless you are at least 70% deep in the throttle, your car isn't much over a stocker.
Why don't tuners increase the low to mid range power? Wouldn't drivability be more fun? Just too much work? @FiveLeeter918 for the rapid response.
Also @mattr66 do you know if the flex fuel tables on non flex fuel vehicles can be enabled and operational? I am asking you because if anyone's tried it, it would be you. The timing Thor, the gearshifting Gaia, the octanium Odin!
Any all comments welcome! Let's learn something about this wild wonder!
