Merlin236
I have a 93 ATX SHO.. I put it in the shop to have two oil leaks fixed. the oil pressure sensor and the crankshaft front seal. The car ran fine after the sensor leak was fixed, but after they fixed the seal the car won't run. It cranks and turns over fine, but won't run.. They tested the timing it has fuel and spark.. Is it possible they messed up the crankshaft position sensor, or the timing belt?
