engine will not run with spout connected
howarjjason
Phoenix, AZ
Hey Guys I am having a problem.... My car will not run with the spout connector in? I pull it out and it starts right up. I put it in while its running and it kills the motor. I put it in when its sat over night and it wont start but as soon as I pull it out it bam it starts....
Any help would be great!!!!
shoon
cliTaurus
Dawson Creek, BC
My guess would be the cam sensor. Might be a bit off on this; but if you pull the SPOUT your timing is ******** ~20 degrees, cam sensor is bypassed and the crank sensor is used to fire cylinders at TDC.
GreenPlus
A-town, GA
unplug the cam sensor and see if it runs better. If so, that's your problem. Its located on the passenger side of the engine bay towards the firewall ~Will
Rockledge
Pluggin' away
Connecticut
Loss of a valid SPOUT signal causes the DIS Module to automatically turn the ignition coils on and off using the PIP signal. This results in a fixed spark timing and dwell (10 degrees BTDC).
My guess would be either a problem with the SPOUT circuit, or a bad DIS.
On my current white 94 project, I was getting a code for 'spout circuit disconnected' even though the connector was on. Turned out to be a bad dis.
