Engine idles poor
97taurus
USA
First I just want to clarify that I have a standard Taurus (not SHO). It is the 3.0L 12 valve V6. I am posting here because I could not find any other site for non-SHO taurus.
Anyway, the problem is I have a rough engine idle. When the engine is around 1300 RPM it smoothes out, but still has some shuttering if under a load. I have a SES light on and it sometimes flashes. In my previous car (1999 Trans Am) that was likely a misfire. The was diagnosed at a Ford service center as having a blown head gasket. So I replaced them. Neither gasket appeared blown to me. The car still displayed the same symptoms so I replaced the plugs, plug wires, pcv valve, air filter, all gaskets that I came across during the head gasket replacement.
The car still runs the same. What else could it be and is there a way to determine what code set the SES light?
Thank in advance.
Mark
SolidState
No Mo SHO
Toronto, Ontario, Canada
Personally, with my SHO, when it runs really really lean, it has a slight miss at idle, and gets a bit raspy at about 3000rpm.
I have replaced my plugs, wires, o2s and am cleaning up the MAF, and it seems to be helping...
but pull those codes!
