jeremy manlief
hello. i have a 95 mtx. i am doing some big maintance to the engine, like clutch change, rod bearings, 60k tune up, etc. the first thing i did when i got the oil pan off was change the oil pump and front seal. that went smooth. next, i change the rear carrier gasket and rear main seal and cleaned the dirt and grease from the clutch and rear seal being bad off of the back of the block. that went smooth. next i changed the rod bearings. that went smooth also. i assembled the bottom end(stud girdle, and windage tray and oil pump pick up) and put the oil pan back on. when i tried to turn the motor by hand, it would only turn so far and stop dead, then i would turn it the other way and it will only go so far and stop dead. i noticed this when i was changing the rod bearings and i thought it was a piston hitting a valve, but i have read that these engines are non-interference motors and the engine was turning just fine by hand when i was removing the flywheel. next, i thought it might be the oil pump so i took back off the oil pan and removed the oil pump and it still does the same. i then took back off the rear carrier and it still does the same. i even loosened the rod caps and still the same. i inspected the rod bearings and they are just fine. now the crankshaft is really stiff to turn and it will free up in spots and still stop dead after you turn it so far. it will not turn a full revolution. i didnt change or mess with the main bearings or caps. could this be my problem? i coated the rod bearings with plenty of oil and i dont think this is the problem. i am using torque specs from the dealer manual and a good torque wrench to torque everything down. any help or theories on this problem will help me in a big way. thanks
