93MTXSHO_STUD
Ok guys going back to school I noticed the old SHO seems to lose charge on the battery if it sits for a while. Say I dont drive it in 2 days the thing will be completely dead. I am thinking a voltage regulator or something is pulling current from something. These are some of the things that I have checked. I went to autozone and they said the alternator and battery were fine. I checked the all the fuses and they were fine. I got the circuit tester(aka wire and a light bulb) and probed some of the fuses in the fuse box located inside the car and about 4 to 5 lit up the bulb. Now Im not familar with these electrical systems and what fuses if any should be active with the car is shut down? Also I used the 12V comes from the factor amplifier supply and put it to my new amp. I probed that and it seemed to glow a little brighter than the other fuses. Any suggestions??
