EEEEEkkkk!
SHOkid13
Take it to the track
Temecula, CA
Okay, just ran my codes after a disapointing dyno run this morning...
21tpp5
21tpvq
I ran codes and found some fun stuff:
KOEO
111 - Systems pass
157 - MAF circuit below minimum voltage
{now what?}
211 - PIP circuit fault
{huh?}
528 - System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch)
{ignore?}
542 - Fuel pump secondary circuit failure
{car stalled? Replace fuel pump?}
KOER
116 - Engine Coolant (ECT) sensor out of range
{engine not fully warm?}
SEFI (Cylinder Balance Test)
9
I am completely stock.
As you can see, I am running pretty lean.
Please help! :help:
SHOkid13
Temecula, CA
please?
What should I do? This computer is much more complicated than the computers I have used in the past.
From what I see, I need a new fuel pump, a PRO-M MAF, a TwEECer, and some big injectors.
Any thoughts? ;)
Dan H
Seattle
If your engine wasn't warm it should have run rich.
I would start by cleaning your MAF, and checking Fuel Pressure.
Maybe a new 155 lph fuel pump.
But I am not even close to an expert on these things.
Try the web site in my signature for additional information on the EEC tests. The 211 code is a problem - that points to the profile ignition pickup, otherwise known as the crankshaft position sensor (CPS or CKP). That sensor is essential for operation of the engine. The MAF signal will not be affected by cleaning the filaments. That code is due to an electrical problem such as a faulty sensor element or a discontinuity in the wiring harness (even unplugging the sensor with the ignition key ON).
SHOkid13
Temecula, CA
Okay, so should I drive it for awhile and recheck the codes to make sure it isn't just a one time problem? Also, is the CPS a PITA to replace?
SHOkid13
Temecula, CA
Acording to shoshop.com the stock for MTXs is 112lph.
Anyone know if moving up in fuel pump output would require a computer modding?
Dan H
Seattle
If you are running lean it suggests a fuel issue.
MAF, Pump, Injectors, etc...
If the MAF was unplugged/disconnected it would run really rich. If the MAF is dirty I belive it will run lean.
155 lph is the largest pump you can buy without upgrading the stock Fuel Pressure Regulator.
You might also want to clean & balance your injectors. I know your car doesn't have a lot a milage, but that just means it did a lot of sitting early in life that can lead to fuel degradation.
somedude_001
Western NY
voulme not pressure, the extra fuel will just run through the return line and go back to your tank... no it won't
have you ever punched numbers into a calculator and it gave you the wrong answer once and a while... no you havent (hopefully) if it throws a code then something is wrong.
personaly I would start with the "116 - Engine Coolant (ECT) sensor out of range
" because it is the easiest.
SHOkid13
Temecula, CA
The MAF may be dirty, what's best to clean it? Brake cleaner?
I'll get a fuel pump next loan I close. ;)
Where/How do I get the injectors cleaned and balanced?
SHOkid13
Temecula, CA
You confused me on this one... what do you mean "no it won't"?
I think that one was just because my motor wasn't fully warm. I'll run them again....
SHOkid13
Temecula, CA
Okay, I ran the full codes test again (after clearing them the last time) and found the following (this time I made sure the engine was hot):
Since this one seems to be something to ignore...
I guess I need to get a 155lph fuel pump, a PRO-M MAF, a TwEECer, Big Butterflies, extrude honed runners, CAI, y-pipe, 2.5" custom exhaust, cams, the zex kit, and then re-dyno the car.
:biggrin:
oh_SHO
Ohio
DO NOT clean the MAF with carb cleaner. Get a electical contact cleaner in a spray bottle and do not touch/break the filaments (obviously). Your injectors will need to be taken to a specialty shop. A shop that deals with diesels a lot would be able to point you in the right direction. Also you might want to consider getting a used set to have worked over so your car isn't sitting.
SHOkid13
Temecula, CA
Alrighty then! Thanks for the heads up!
:thumb:
