BaySHO Performance
Problem: blower motor comes on when the ignition is turned on before starting the engine, even though the EATC is off. Can’t get the blower to turn off.
Background: ’95 MTX, 155K miles. I drove it home from the client’s house, everything was working fine. Replaced the radiator as preventative maintenance (disturbing the D code CCRM which is included in the AC circuit), and resealed the oil pan. New jiggle valve thermostat also installed. Put radiator flush in it and ran the engine with the heater set to 90. Ran it until the thermostat opened and topped it up until no more air came out (so no low coolant). Then ran it for a further 10 minutes per instructions.
While the engine was running, I noticed that the AC compressor was operating even though set to 90, and the fan was running (presumably because the AC was on). Turned the engine off, but now the blower comes on with the ignition turned on but engine and EATC off. Can’t remember whether it was doing that when I initially started the car. I don’t think so.
EATC working fine apart from not turning off. Register selection OK, blowing hot or cold depending on the temp setting, blower motor speed varies with thumbwheel. The only oddity is that if I go to ‘MAX AC’ and then set the temp to 90, the ‘MAX AC’ indicator is still lit.
Tried replacement CCRM: no difference. Its wiring looks fine. Battery voltage OK. All fuses fine. No engine codes.
Ran EATC self test on a warm running engine. Came back with 888. Gets generated if:
- Vacuum system inoperative (it’s working fine)
- AC not working (it is)
- Bad CELO switch: Cold Engine Lockout / Temp Control Lockout Valve in one of the tubes going to the heater core. Stops the blower motor coming on until the engine is hot enough to warm the interior. I disconnected the CELO switch and turned the ignition on: no difference. Same with disconnecting the ECT sender. No pinpoint test for this problem in the manual.
Has anyone come across this problem before? My best guess is that the CELO switch got clogged from all the gunk loosened by the radiator flush. Another possibility is that the EATC got damaged by setting the temp to 90, but that’s a long shot.
Thanks
Nick
Thanks
Nick
