E.A.T.C gone crazy
URLACHER54
Gambrills, Maryland
this morning while driving my E.A.T.C started flashing on and off every10-20 seconds but now while sitting at idle ths screen is fine, this is an upgraded hard button version but dont know what it came from and its been in here for a while. any ideas.
SHOspazz92
Banned
Triad Area, North Carolina.
Check your battery cables.
-Sam
PacoLoco
Chicago, IL USA
I had the same thing happen to me recently. Check your alternator. It turned out that the alternator was overcharging the battery causing "crazy" things to happen. Use a volt. meter to see how much voltage the alternator is giving to the battery. Hope this helps.
MD Ever
MeanestDad Ever
South Lyon, MI
I recently had the same problem and it turned out to be my battery cables. The positive cable was loose and corroded at the starter and had rubbed through up by the radiator. I replaced both cables. Works great now.
Dan H
Seattle
Your Alternator is bad, same thing happened to me and it took forever to figure out what the problem was.
