NEp8ntballer
cyber ninja
Well it's summer in CA and I'd like to let the breeze in since my AC isn't fixed and right on cue the SHO decided to act up. It started out being intermittent and has become a bit more permanent it would seem. It usually works alright in the morning, but once it sits in the sun and warms up the motor won't go down easily. It will start to go and then stops after a split second so it takes many a press to get it to go. giving it a helping hand doesn't make a difference. Maybe the assembly needs some grease?
I replaced the one touch power down module and placed another switch set on it and both failed to fix the issue. At this stage I'm thinking it's either the window motor or the wiring. it goes up with no issues but down is when it likes to cause trouble. Thoughts?
