sperold
Last to Know
My 95 has a mangled DIS module and the wiring connector on the windshield side of the DIS module is mangled as well. The module has cracks in the plastic material on the left side and the wiring connector shroud is broke. It has made contact with the shock tower during a subframe lowering to change the steering rack.
Odd thing is, it runs fine with this visible damage.
I am wondering if I sealed the damage properly with a silicone product and then sealed the wire connector to module interface, would this be a permanent solution.
Has anyone repaired a module this way?
