MK-2000
Is There Anyway That I Can Put A Different Engine In My Gen3???
well i depends on your DMV laws in your state for starters and you will have to change your pcm and some wiring depending on the engine and years i was planning a engine swap in my 96 SHO to the V6 24 V engine out of a 98. and it took me 2wweks to figure out some of the wiring and changing the power box under the hood due to 98 they had a diode for the PCM and A/C units so be for start changing do some resreach on the setups and wire that is important due to the OBD codes.MK-2000 said:Is There Anyway That I Can Put A Different Engine In My Gen3???
Why? What is wrong with the 3.4? Do you have a cam failure? For the money you would spend buying and installing a new engine, you could fix your existing engine (if there were problems) and then have plenty of money left over for say....forced induction.MK-2000 said:Is There Anyway That I Can Put A Different Engine In My Gen3???
