stangracr67
Finally got my car running much better after upper 60k and replacing a bad Crank sensor. the car still idles rough. also I have done a cylinder balance test about 5 times and everytime only cuts 5 cylinders. after the fifth one it just idles at about 1600 for about 15 seconds then i get a flash, 3 sec pause, flash. seems like its not testing #6. when it does this does it cut fuel or spark? i notice that when it cuts #2 the idle goes down but it doesnt run any rougher. I know that #2 and #6 are on the same coil circuit could it be a coilpack going out. Compression on all 6 are 21-215psi.
