crazy radio
89shofun
Guest
franklin wi
installed new radio now it lights up but thats it. when i turn on headlights it dimms, when i try to turn it on it pulsates, some reason my radio wire harness isnt getting enough power hlp in needed, i have tried it directly to battery works fine can you guys hlp. Were does the power wires go for my radio
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Check out the owners manual and look up "fuse" in the back. Go to the page and it will list all fuses and what runs on them. You will be able to find the one for your stereo in there.
89shofun
Guest
franklin wi
i plan on making new harness for radio power any ideas maybe runnin wires from batt or something were do the power and memory wires go to for the radio can they be swapped thx
mlatten
Mons-taurus
Suffolk, NY
Are you sure that you have all the grounds hooked onto it. I had to add an extra one onto my stock CD player before it would play - but it lit up before I grounded it. If you're using the stock harness, there's a jack about a half inch long that serves as the master ground/negative. If not, find it in the harness you're using, and touch it to the back plane of the radio, it should work.
Best of luck, and remember, voltmeters are your friend, as long as you use it in parallel.
Matt
etc1006
Baltimore, Md.
Does your car have premium sound from the factory? I remember when I put a new stereo in my Mustang I didn't know about the "other" harness... The one for the regular stereo. The install guy at the store told me what was happening to me was the factory amp was in overload and not letting sound through because the new stereo was high output. Everything lit up and all, just no sound, til I found the regular harness. Dunno if this is your problem, but lots of folks do come across this when they swap for an aftermarket h/u...
89shofun
Guest
franklin wi
i wired in the factory plastic clip then connected it works fine now im trying to wire in the clip for the speaker wires but i need diagram of the colors going into radio thx
89shofun
Guest
franklin wi
had to rewire my amp also crazy work i got all of it done now im going to sell my car 400 must go lol lata
