crank timing sprocket threads
ManySHOs
South Jersey
Does anyone know what the thread pitch is for the timing belt sprocket on the crank? I will need to swap mine out and need to get the appropriate bolts for my harmonic dampener puller.
It seems that I also have the "crank cancer". I'll know for sure once I get that sprocket off but everything I've taken apart indicates that this is the issue. I'm hoping that the crank survived and I just need a new key/sprocket and possibly a new dampener.
I'm looking forward to driving her again with all of the power back!
Ian
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Ian, if you need a new bolt, PM me.
Damn I'm a *******.... Yes, either grind V/C bolts to use, or use the long bolts from the timing cover.... Or, listen to Chris below..
I thought you meant crank bolt. My bad.
Mr Anonymous
Tire Wall
IIRC it's either 5mm or 5.5mm and my guess is at that size there is only one pitch.
You do know that you can use timing cover bolts, right? The long two on an MTX are perfect. For ATX'ers with only one long bolt you may have to take a trip to Fastenal.
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
I use the 2 longest bolts that are holding on the timing cover, to pull the timing belt sprocket off. They are the same thread pitch.
Looks like Chris beat me to it.... doh
Storm-Chaser
Shit Louis
If Fastenal doesn't have it, they can usually get it.
As an alternative, you could use threaded rod-stock, cut the whatever length you need. Last time I inquired, you could get a broad range of metric threaded rod-stock in 3 foot lengths.
RAYJAY
WHO ME ?
UNION DALE PA
if you check even home depot or lowes they should have them in there hardware section
Jeff
ManySHOs
South Jersey
Thanks all! Oddly enough I didn't get any email notifications for these responses. After digging deep into my memories, I remembered that I once used a timing cover bolt. I used the two longest ones as suggested and just pulled off the sprocket using a puller.
I'm not sure what the deal is with my car. Both the harmonic balancer and the sprocket had the slightest amount of play. From what I recall, they shouldn't have any play. I could pull them towards me ever so slightly but I needed to use my puller to remove them from the crank completely. It appears that there is a ridge on the key; if it is in fact worn, it doesn't appear to be worn uniformly. I think the wear is more towards the oil pump. There's a lot of rust dust on the crank snout. I've wiped some of it off and the crank seems fine (whew!).
Another potential problem is that one of my crank sensor screws has worked itself loose and is halfway out of the sensor. I was able to jiggle the sensor a little bit.
I think I'm dealing with two issues here; a worn key that I caught in time (I hope) and a bad signal from a loose CPS. Very odd...
To add to this, I knew I had a timing problem when the car starting running rough in the summer. I pulled the upper timing covers and found that the adjustable sprockets had walked. After resetting them to 0 retard/advance (and installing lock washers) the problem was better but never went away. I wonder if the belt stretched or jumped a tooth when that happened. If the crank bolt was loose, it may have exacerbated any key wearing issues. I may never know. I didn't have time or a place to work on it so I ended up parking the car until now. Thankfully I have another daily driver, time AND a place to work on the car again.
Thanks for all of the help!
I think I have a line on a used key, sprocket and balancer. I have a new timing belt and crank sensor to install. I hope this fixes her; I actually miss driving the SHO (sometimes). :)
Ian
