Hey guys I am trying to remove the crank pulley... I removed the center bolt and put the puller on the pulley... It does not seam to budge and Ideas or tips to remove it .... Help is much appreciated...
your suposed to use a harmonic balancer pulley puller. you can rent or buy one from your local auto parts. also you might get away with a steering wheel puller.
good luck.
