200K_SHONUT
I am hoping someone out there can help me. My 89 SHO was suffering from the dreaded Crank Cancer, I pulled the Crank Damper off and found that the key holding the damper and the timing sproket had split in half. I have replaced the key, as well as the timing sprocket, oil seal, etc.. When I pulled the timing sprocket off of the crank, (after pulling the timing belt off) the crank moved. My clutch has been slipping lately but I'm still able to drive it, it took a little effort to move the crank, should have oiled it before trying to pull the sprocket. So needless to say, my engine is out of time. I can get the Crankshaft back to TDC, but am pretty sure the cam sprockets have both traveled, due to my ignorance (had to touch them). My question, after all of this writing, is can I just line up the timing marks on the cam sprokets with the timing marks on the side of the engine (facing straight up) with the crank at TDC? Will that work? Or do the cams have to be on the same cycle (inexperience talking here) or do I just make sure they are lined up and go with that?? Any help would be appreciated. Thanks.
