cooling problems
zerg1024
NJ
ok well i changed my thermostat the other day and got the instructions off of shotimes.com and now the coolant doesnt flow unless i have the heat on. what could be the problem could there be an air pocket in the system or what?
projectSHO89
SHOless In St L
The heating system should have nothing to do with coolant flow.
Coolant is supposed to ALWAYS flow through the core.
Did you perhaps install the thermostat backwards?
Steve
zerg1024
NJ
i dont see how i did install it backwards. i put it in with the spring and all into the block.
zerg1024
NJ
well the temp gauge goes all the way up to N and only goes down to the O when the fan kicks in. but when i turn on the heat it goes down to R and M. could my waterpump be going?
naval-avi8or
Chesapeake, VA
Probably just have some trapped air in the system. Was the new thermo a -B revised that has the little jiggle vavle to help remove trapped air. If so did you place the jiggle valve at the 12 O'clock position.
If your not getting heat from the heat inside the car then you have a blend air door actuator problem. This could be a bad actuator a disconnected actuator arm or a vacuum supply issue to the valve.
zerg1024
NJ
yea it is a revision B and i did place it at 12 oclock. i do get heat in the car too. so i am confused about what it could be.
naval-avi8or
Chesapeake, VA
Ok I miss understood your first post about the heat. Yes a fluctuating temp gage is generally air in the system and will burp out over time. Also keep in mind that there is a seperate sending unit for the gage than the pcm and fans.
zerg1024
NJ
well if it is air in the system do u think i should do a full system flush and fill? i also changed the temp sending unit in case u were wondering.
naval-avi8or
Chesapeake, VA
No you don't need to flush and fill. That will just get more air into the system. You just need to run the car under normal operating temps (may take several cycles). Be sure to keep the coolant recovery bottle properly serviced. Some have had luck by messaging the upper radiator hose to help burp the air out (at operating temp).
