Marccus
I still can't get my secondaries to work.
I've tried 3 different groups of solenoid electronics and the cylinder (I don't know what to call these pieces) and still nothing. The position of the butterflies remains in the same position as when the car is off - open
I've installed a new PCM, still nothing
I disconnected the wiring harness connector at the PCM to test the continuity of the lines between the pins on the PCM connector and the pins on the connector at the solenoid.
There are two wires for the connector, Red and light green/ pink.
My wiring diagrams (the large fold out kind) indicate the following:
R line as 361 14 R AB
LG/P line as 965 18 LG/P AB
Line 361 is connected to Pin 37 on the PCM
Line 965 is connected to Pin 32 on the PCM
There is continuity between Pin 37 on the PCM connector and the appropriate pin at the solenoid connector, and Pin 32 and the appropriate pin at the solenoid connector.
Thus, there is no open in the wires.
I get the following voltages:
Key in off position: wire 361 is 0 volts
wire 965 is 0 volts
Key in start position or engine on: wire 361 is 12 volts
wire 965 is 0 volts.
There is no continuity between wire 965 and ground.
Therefore wire 965 is not grounded and the wire from pin 32 (965 18 LGH-P AB) on the PCM connector is only connected to the pin on the connector at the solenoid. This is also shown on the wiring diagrams.
How is wire 965 energized if this wire has no other connection from Pin 32 at the PCM except the pin at the solenoid connector?
Can anyone advise?
wire 965 is 0 volts
How is wire 965 energized if this wire has no other connection from Pin 32 at the PCM except the pin at the solenoid connector?Can anyone advise?
