Compression help
2slosho
tampa
I recently checked my compression and wanted to see if others drew the
same conclusions as I have.
1-60
2-30
3-90
4-155
5-90
6-155
I have a 95atx. New plugs,wires, upper gaskets, except head.
Are both head gaskets gone?
TIA dave
Could be rings, valve seats or head gaskets. What other information do you have?
2slosho
tampa
Haven't taken the heads off yet. I know oil is leaking out of the rear head, below the exhaust manifold. That is the only place. I never noticed any burning or loss of oil. I WAS losing about 1/4 quart per oil change in the spark plug wells.
Also, when doing the comp test I notices water spewing on the back firewall. So i know the rear gasket is gone.
It's looking more and more like I may just purchase a mtx. Especially if this turns out to be as bad as it's looking. cuss
munkee
Too busy...
Missoula, MT
Wow! Does that motor even run? Do you know exactly where the water splashing on the firewall is coming from? Has it been sitting for a while or something? What kind of plugs and wires do you have?
<small>[ May 29, 2003, 10:31 PM: Message edited by: munkee ]</small>
2slosho
tampa
Runs. barely. Sounds like a Powerstroke diesel. The water appears to be coming from between 1 and 2.
Plugs and wires were Motorcraft. I changed the plugs and wires last week. Wires are Taylor 8.5.
I can see if I can get a sound clip for you.
2slosho
tampa
Probably both of them. At least that seems to be the consensus. Valve covers are already off so removing the heads won't be that much of a PITA. At least I'll get to adjust my valves.
2slosho:
THAT would be the information I was referring to. Why make us guess when we have less information than you have?
