Codes 212 - 219
SHO13
Alaska
I recently moved back to hot and humid Florida. Shortly after getting here, my SHO started having some sort of ignition problem, feels like an occasional miss.
The problem only happens after the car has been sitting a while (overnight). It starts up fine and then shortly starts into this erratic engine operation. The tach starts jumping around about 200-300 rpm and feels like its missing on a cylinder. After about 5 minutes of operation the problem goes away and doesn't seem to reappear.
In my effort to troubleshoot. I decided to replace my spark plug wires (long overdue - 13yrs 170K) w/Taylor 8.2mm and put new plugs in. Performance increase was impressive. However, the problem did not go away.
I spent a while doing searches, my grounds are good, less than 1 ohm battery-firewall-intake. I pulled the connectors to the DIS, coilpack, MAF, SPOUT? (4pin grey connector passenger side/intake), IAB and cleaned the contacts with electrical connector safe solvent. Wiggle test didn't reveal anything either.
My DIS and Coil pack are original. After watching the problem for the last couple of weeks. I noticed the problem is worse when I leave the car outside in the humid air instead of the garage.
I went to Autozone and they apparently can test DIS modules, but they didn't have the wells sheet for my specific DIS F147 (if I remember correctly).
Since this problem is inermittent and shortlived (less than five minutes), its been difficult to isolate.
Codes 212 - 219. Any Suggestions.
Rockledge
Pluggin' away
Connecticut
Continuous Memory DTC 212 indicates a loss of IDM input to the PCM. Possible causes:
-- Open circuit.
-- Shorted circuit.
-- Damaged ICM (DIS Module).
-- Damaged PCM.
DTC 219 indicates the spark timing has defaulted to 10 degrees BTDC. The SPOUT signal has a variable duty cycle with amplitude that varies from 0.4 volt to B+. In the event of a SPOUT failure, the ICM will generate a fixed dwell and constant spark angle based on CID and PIP signals (FMEM mode). Possible causes:
-- Damaged SPOUT circuit.
Based on the above, I'd say it's a good bet your SHO has a problematic SPOUT signal/circuit. It could very well be a bad DIS module, but you should check the SPOUT circuit out as well.
Since the SHO DIS system and the Super Coupe 3.8L DIS system are identical, you can find several good and relevant pinpoint tests for the SPOUT circuit in this link, beginning with test N16:
http://www.frontiernet.net/~miketoni/images/tbird/DISnostart/DIS No Start.htm
