Clogged Catalytic Converter
jae
'93 Taurus SHO
Chicago Heights
Inheriting my uncles 93 (believe its a 93) Ford Taurus SHO [Automatic], thats been in storage for about year now. He said the only thing wrong with it is one of the catalytic converters are clogged. Anybody know about how much about how much a new or used catalytic converter will cost? I also seen some additive that suppose to clean your converter on autobarn, anybody know if this stuff works?
Thanks,
Jae
TYSHO
Earth
A high flow performance one will be less money than OEM. Call an exhaust shop and ask around, price to remove both cats and replace them with some decent ones. Best to replace them both if one has failed.
jae
'93 Taurus SHO
Chicago Heights
and high flow performance cats would cost around how much? im hoping not $500 since i dont have that kind of money atm
Ishodu
The cats shouldn't be more than 100 each. It will cost some labor to install them also. That is if you can't do it yourself.
jae
'93 Taurus SHO
Chicago Heights
cant do em myself... everywhere i looked (napa and many small websites) had cats for like $260/ea or $550 for two. have any links where i can order directly off the internet for that sweet cheap price :)
btw thanks for the help
TYSHO
Earth
Just call up a shop and ask how much the cheapest one is that can fit in your ride, you might be surprised. Most rates around here to install are $30 or so for each. IIRC, I was going to get some through Jegs, though not advertised in the mag, for like $60/each. I think they were DynoMax.
rangerj
Brunswick, Ohio
You will also need to determine WHY the converter became clogged in the first place. Was the car running rich due to a failed O-2 sensor, which would over a period of time cause a converter failure? You could have a rich condition due to a clogged air filter, poor spark plugs, poor plug wires, an IAB problem, and a few other things. The point is that you simply cannot just change the converter(s) without determining the cause of the failure.
If you replace the converter(s) and do nothing else you will possibly have to get the converters replaced again. It is a matter of time. If you cannot afford to maintain the car maybe you should consider selling it.
TYSHO
Earth
Or, you can post in the WTB section for a "used" OEM y-pipe with good converters.....I know there is some out there. Be specific as in it is for the ATX.
jae
'93 Taurus SHO
Chicago Heights
thats why im takin it to a shop like Midas or Napa to check whats wrong with the car. i just wanted to know about what the price will be and if anybody had any cheaper prices than what i was finding. i cant afford to maintain it because i was looking for cheaper prices???? :madflame:
jessemachone
No Mo SHO
Scottsdale, AZ
Ebay
Stay Away From Muffler Tech On E Bay! You Will Get Robbed! They Are Out Out Of Modesto Ca. You Can Easily Spot Them On E Bay. They Use Poor Grammar And Use Others' Pics To Promote Their Product.
I would just get a whole new y pipe from sp motorsports or midwest sho or something.
