changing rod bearings
HELLBENT93
Phoenix, Az USA
ok i am planning to change the rod bearings and im going to use the instructions of of kurt metros website. It states that you need a oil pump pickup tube gasket. Well I went to Ford and they dont have it and neither does autozone or checker. Is it possible to use the gasket that is already in there or would that be not such a great idea?
Get an egr gasket. You may have to modify the square hole on the middle to fit properly but it is the same general size. Eye it up to the gasket you remove.
