SHO me the $$$$$$
Okay so I dont come here often but when I have a problem i know this is the place to go... have been searching for over an hour now and I have found many "possible" solutions to my problem so I figured I would just ask...
symptoms...
Couple weeks back headlight switch stopped working but I could turn them on with the auto on/off... (coincedence?)
Car was running just fine and pulled into parking spot at work..
come out from work... turn key, hear pump, car starts just fine...
Go to back out... and car just shuts off !!??
Turned key off... try to start listen to pump but now pump doesnt shut off ??
Keep trying... no start and then I notice my cooling fan running... I have never heard it run on a cold start prior??!!
Go get some gas... nothing
Based on what I have found here I am leaning towards the IRCM/CCRM...
I checked fuel pressure and with the key in the on position... pump running... it is fantastic... go further to crank and pressure goes away and the pump stops ??? little bit of ether and she tries so i assume there is spark ??
IRCM/CCRM The performs four functions on the SHO:
1) EEC Power Switching
2) Fuel Pump Relay Switching
3) Cooling Fan Power Control
4) A/C Clutch Control
Any help would be greatly appreciated
92 MTX with 144K
Forgot to ask... where can you buy a CCRM ??
Scott
symptoms...
92 MTX with 144K
Scott
