Catless dp ?
yo tony
Manning, SC
Anybody using catless dp I have a couple questions, any smell? Ppe livernoise or unleashed make a difference? How bad is the install? Using unleashed 3 bar tune currently. Thanks for your time
As long as you retain the 3rd cat and the turbos are working properly, the smell should be minimal. Still would advise catted if you can go that route.
The bolts do tend to rust, so be prepared to drench them thoroughly in PB Blaster or similar product for a while before attempting removal. I would also doublegasket (with new OEM gaskets) the joint between the downpipe & the catback, as that is somewhat prone to leaking.
Any of the 3 (PPE, Livernois, Unleashed) = :thumb:
