Car won't start
SHOitoff95
Michigan
Well the other day I decided to put my system back in and everything was fine till I went to adjust the bass and when it first hit my car stalled. So I disconnected the negative battery cable and let the computer reset and then I tried starting it and it just wouldn't start. So I pulled the system out and the LPM out just in case, let the computer reset agian and it still wouldn't start. When I try cranking it you can hear like a pop like it wants to start but it just won't. I thought maybe the fuel pump took a shit but its getting fuel, so I put on my spare DIS module and it still wouldn't start. Anyone have any idea as to what cuold be causing it to not start. It ran PERFECT before this.
wood_e
The dude
Ames, IA
maybe it hit so hard you tripped the fuel pump cutoff switch in the trunk? try reseting the switch and see if it starts.... then turn the bass down....
SHOitoff95
Michigan
YEAA I decided to jumpstart my car and try again and it decided to start and run this time. Guess that system is gonna stay out.
Anthony1238
Billerica, Massachusetts
after i installed my system, the first bass hit shut down the fuel pump switch.. i had no clue what happen... but in your case I would invest in a optima battery and posible a capiactor... what kinda of system you pumping?
SHOitoff95
Michigan
It's only 2 12's with an 820w amp in a bandpass box, but they do hit pretty hard. Hard enough to shut off the fuel pump wink
thatSHOguy101
