Car wont run!!!!!!
Stewben
Guest
Hodgenville KY
Ok, I know this seems stupid but, I went and changed my spark plugs and wires the other day, and now I cant get the front wires to go down all the way. I am pretty sure the reason its not running is because its not gettin a good spark. So any help would be greatly appreciated!!
Machspeed
Former 1991+ owner
Santa Barbara, CA
Uhh...how would you like us to help you? You need to get those wires on so they are even with the valve covers.
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
This may even sound worse saying but are you sure the right plug wires are going to the right spark plug. Cause they are numbered. And they are all different links. So is that your problem? You just don't have enough to get it into the hole. Are u feeling the conformation snap on to the spark plug?? Hopefully this helps.. But you probably knew all of this already!!! But I thought i would chime in and try to help out! thumb Good luck!!
Mr Anonymous
Tire Wall
What plugs and wires are you using?
If you're not using the Motorcraft AGSP32PP plugs, you may have bought one of the many aftermarket brands which are not the right length and create problems properly seating in the plug wire boot. Similarly, a lot of the aftermarket wires do not share the precision fit of the Motorcraft WR-4033 wires, and aftermarket wires with aftermarket plugs may be exacerbating the problem.
