car dies n wont restart intermittently
Mikes 93 SHO
Hey guys, i just got this 93 SHO with the 3.2L a couple weeks ago, and its giving me problems. the car will run fine for a while then will die. The amount of time it will run isnt consistant at all. Sometimes it will start right back up, other times it wont start for two hours. I did find that it is losing spark. Already replaced the constant control relay module, and ignition control module with no change. Trying to find an ignition coil but cant find one with the slot on the connector in the right place. Im tired of being left on the side of the road and desperately need help. Thanks
Mikes 93 SHO
That was my next step but i havent seen one do this before. And it still reads rpm when it wont start. But i will try it, they have one down the street for $93.99. Thanks
tery
Silvia survived the purge- summer car
minnesnowta
Good luck with it...If you just got it..93...change the fuel filter!. I've bought 5 in the past couple years and the ALL had terribly clogged fuel filters. Probably not related to your problem, but just my 2 cents..
Mikes 93 SHO
Already did, did that before i had this problem. And when i press the schrader valve fuel shoots up to the hood every time
sperold
Last to Know
Take a look at the water pump weep hole on the bottom of the snout (usually need a dentist's mirror). If it is leaking, it douses the crank sensor and you find yourself on the side of the road.
It is fairly hard to change the water pump, but much better than swapping the crank sensor. And you might get away from changing the crank sensor, if the water pump is leaking. I had a bad pump that soaked the sensor many times, but the sensor survived.
my experience is that once the crank sensors get shaky, they never get better, so I would just change it.
be sure to get the gap set correctly or you'll get to do it again right away... the magnet (on the bottom side of the gap on the sensor) wants to clamp itself to the shutter wheel, making the top gap too large. make certain your top gap is not too large!
Mikes 93 SHO
Well, started changing the crank sensor and got the timing cover off to find is was coated in oil. I figure the oil would get on the sensor and make it quit reading similar to sperold said with the water pump which thankfully isnt leaking also. So im gonna figure where the oil is coming from (probably cam seals or pump seal), fix it then replace the sensor just to be safe. Ill keep you updated on if it solves the problem or not, but i believe it will
you will still need to change the crank sensor. in my experience, once they get flaky they never recover.
oil leaks in that area can be: cam seal, power steering pump input fitting seal, power steering hose leaks, power steering pump shaft seal. the order I listed them is the order of frequency in my experience.
Mikes 93 SHO
It was engine oil so i didn't take any chances and replaced both cam seals and pump seal. I'm already there, and they are cheap enough to save my time so figured might as well
Mikes 93 SHO
After fixing the oil leak and replacing the crank sensor to be safe, drove it bout 50 mile yesterday evening (all within 10 miles of my house) and didn't havve a single problem with it. Thanks for the help
Mikes 93 SHO
Now i get to upset my neighbors by cleaning my injectors, hopefully they are at work and the fire dept doesn't get called out
just put about 4-5 oz of acetone in per tank for 3-4 tanks. that will clean them up just fine without causing the fire drill. just don't drip it on any paint you want to keep...
shobroooo
