can't pull codes
three50one
Gettysburg, Pa
I had this issue before and it fixed itself for awhile. Girlfriend described a blinking SEL. While I can assume this is a missfire I would love to be able to pull a code. I've checked the fuse and its fine. The lighter works just fine if I'm remembering my manual correctly. I can pull them when the car feels like it. Id say I have a 30% chance of getting them.
Has anyone had this issue or know what it could be?
BamSHO
South Williamsport,PA, US
My silver 98 started that before I junked it. Couldnt pull codes or do monitor when it was running. Didnt check into it before I scrapped it. My new black one is fine.
Brian Michael
98 black Gen3
three50one
Gettysburg, Pa
As far as I can tell it's something under the hood. Was able to pull codes when I tore apart the intake and then couldn't after a couple heat cycles. Wiring was good so I'm stumped with it. Runs great though. Plugs looked great.
three50one
Gettysburg, Pa
The cause of this ended up being the harness that sits behind/under the battery. Took that big plug apart and reseated it and haven't had the issue since.
