The only code my 91 car is putting out on the KOER test is 41 which indicates system lean on the back HEGO sensor. I have replaced the Y pipe and cats, the O2 sensors, the fuel filter, cleaned the MAF and did a 60M mile maintenance. I tried swapping the O2 sensors and got the same trouble code. I pulled a back plug and it was ashen color, confirming it was running lean. The front plugs were slightly carbon fouled. I have checked and double checked for a vacuum leak, but none were found. The cylinder test also came back negative for problems. I have read every tread I could find on the subject and am still at a loss as to what is wrong. It is probably something simple, but I am too close to it to see it. Please tell me what I am missing.
