cable shifter snaped!!
Cocoa,Florida
welll i wasdriving today and as i went into 4th gear,
SNAP there it went!,luckly i knew this day was coming
so i have a rod shifter in the trunk,and a new dynomax
catback setting in the garage,so i was wondering besides
the exhaust bend is there anything else i need to put this
in??
any cronic snags people run into when instaling a rod shifter?
please lemme know i plan on starting the install tonight!!
thanks everyone
Brian
SHOGIRL1994
ExFSHOCmanager
Jacksonville, FL
I was going to say I have an extra set of cables in my trunk but doesn't look lik you need them. :) I'm curious about the rod shifter install too, let me know how it turns out and what I should expect because I definitely want to do that before convention time.
SHOslyter485
Fort Collins, CO
Besides having all the correct brackets, it really isn't a bad install. The only problem I had was where the end of the resonator connects to the rest of the catback system (you can see a little notch in it where the clamp holds these pieces together). That was a pain to get apart. Cutting those old cables to the shifter was hard too, but it sounds like you got half of that completed already. Make sure you **** the shifter ball and get a new exhaust gasket. Good luck with the install!
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
The rod conversion is a snap, we did it on Jasons 89...easier with 2 people, one to work under the car and another to dissasemble the console and cable shifter. Installation is a snap and is in shotimes. Let me know if you need a hand Brian, I can come by tomorrow if necessary.
Cocoa,Florida
thanks guys went to shotimes and got the step by step
it seem's to be going smooth so far,thank god i dont have
to drive this thing as a everyday car though!!!...LOL
