green91SHOPlus
Aren't SHO's great? Well, the engines, at least? Everything else is made by ford, therefore it's all total crap. Anyway, I've been having near-constant battles with my cable-shift ends actually staying on the transmission, and now, it's doing the same crap on the shift arm (shifter, or whatever it's called) side. I tried to fix it, but when I did, it wasn't moving in any direction. I got so fed up with it, I pushed on the lever until it broke the housing, so now I need to replace it all. My question is this: are the shift arms inter-changeable for the rod and cable shift? Somebody before me had cut the shift arm on the rod shift in half to make it a "short throw" shift or something, I don't know. But if I'm going to put that rod shift on, I want to replace the shift arm.
