munkee
Too busy...
I've got a problem with my 92, one that I had before with it. It won't turn over. I replaced the battery, wires, and starter a few months ago, then the rod bearings and it's been running great since then. The gas mileage was a bit low though. I drive truck so it sits for a couple of weeks at a time. A few weeks ago after a run I got in the car, let the fuel pump prime then tried to start it. It strarted to turn over but stopped, as if it was stuck. I held the key on for a couple of seconds, at first thinking that it was just a slow turnover from a weak battery but let off when it didn't keep turning. I cycled the key, let it prime, then tried it again. This time it turned over really fast and I had to crank for several seconds before it caught and fired. I figured the fuel had just drained back. No problems whatsoever for a couple of weeks. Then, I had to take a load out to Wisconsin just before thanksgiving. I pulled up to the office and hopped out of the car to get some paperwork. When I got back in, I thought the fuel pump seemed kind of loud. I backed up to the shop and shut the car off while I threw my stuff in my truck. I try starting it so I can park out of the way, and the pump doesn't even prime. I tried turning it over twice for 3 seconds at a time with 30 seconds in between but no go, I know the fuel pump is dead so I just leave it. I got a chance to work on it today, dropped a new walbro 190 in it that's been sitting around and try to start it. All it does it click once every time you hit the key. The battery has full charge, all the connections are tight, no corrosion, pump primes now, but it won't turn over. The new starter hasn't even been on the car for 5000 miles yet. Does this sound like a burned out starter or something else? Thanks, Chris.
